FAULT FINDING
TEL: 01706 436600
Problems with electrical systems can be frustrating and costly if faults are not found quickly and rectified efficiently. Our engineers respond quickly to your call and once they are on site they have the experience to maximise the chances of identifying faults as soon as possible. Global Switchgear engineers are trained to approach fault finding in an effective step-by-step and systematic manner which achieves rapid results.
Our engineers have the expertise to identify the cause of problems that you are having with your existing equipment and recommend modifications to correct the fault. We can modify existing equipment to incorporate changes to your protection or control systems. We can repair damaged components on site or in our workshops.
Global Switchgear is fully committed to getting your electrical systems up and running...fast.
